Can I export the Multi Attribution report and embed them somewhere else?
Cloud Auto-hébergement
Yes, you can export the report and embed them via an iframe into
a different website or app. You can also add the Multi Attribution widget to your dashboard. If you need access to the raw data, you can use the Live API or On-Premise users can directly access the raw data in their MySQL database.
