Which analytics reports are provided by Users Flow?
Cloud Auto-hébergement
Users Flow adds several new reports and widgets to your Matomo:
- Users Flow report that visualises how your users navigate through your website or app. Multiple options let you dig deeper into several reports from there
- The Top Paths report shows you which paths were used most across all interaction steps
- The Overview report lets you explore the steps your users took in a tabular way
On top, popular Matomo features are supported:
- Apply Segments: dice your Users Flow reports exactly the way you need it
- Scheduled reports: receive your Users Flow reports by email, MS Teams, Slack or SMS or send the Users Flow reports to your clients.
- All Users Flow widgets can be exported.
- Users Flow reports are shown in the Matomo Mobile app for Android and iOS.
- Request all UsersFlow reports via the HTTP Reporting API
Next FAQ: Analyse Top Paths reports
Previous FAQ: Analyse Users Flow reports
