How do I control how many days must pass before a crash is considered disappeared/reappeared?
Auto-hébergement
There is a measurable setting that controls the number of days a crash must be absent before it is considered disappeared/reappeared.
Please follow the below steps to configure the no of days it should consider until a crash is disappeared/reappeared:
- Login to Matomo as Superuser.
- Navigate to Administration
> Websites > Manage > Edit.
- Scroll down to Days until a crash is considered disappeared.
- Add the no of days as value. E.g
20if you want CrashAnalytics to consider a crash to disappear/appear after 20 days. - Save.
Note: If you change this value, you will also need to invalidate and re-archive old reports for them to change. Learn more
