Can I fetch Users Flow reports via the Matomo HTTP Reporting API?
Cloud Auto-hébergement
Yes. Users Flow reports are available through the Matomo HTTP Reporting API and can be requested in multiple formats, including JSON, XML, CSV, and HTML.
This makes it possible to automate reporting, export Users Flow data, integrate user journey analytics into external applications, and build custom dashboards using Matomo data.
Refer to the Reporting API Reference.
