Why are my Google keywords not showing up in the Search Keywords report?
Cloud Auto-hébergement
Google search engine keywords will be imported once your website has been configured and approved in the Search Console. When you create a new account and approve it in Search Console, the data will be available from this day onwards.
If no keyword shows up in your reports even when you have configured it correctly within Matomo, you can try to trigger the import manually on console.
Review the Import Search Keywords setup guide or use the Quick Connect option for Matomo Cloud.
