Can I fetch Multi Channel Conversion Attribution reports via the Matomo HTTP Reporting API?
Cloud Auto-hébergement
Yes, the Channel Attribution report can be fetched in different formats such as JSON, XML, CSV, HTML and more, so you can integrate your measured form data anywhere. Read more about the Matomo HTTP Reporting API and view the Reporting API Reference.
