Is it possible to apply segments to the Multi Channel Conversion Attribution?
Yes, the plugin lets you segment your visitors in advanced ways and you can apply any of the over 100 Matomo (Piwik) segments as usual.
Next FAQ: Can I fetch Multi Channel Conversion Attribution reports via the Matomo HTTP Reporting API?
Previous FAQ: Is it possible to change and increase the number of days prior to the conversion to more than the default 90 days?
