Tarte au Citron is a widely used French open-source consent manager (CMP) that includes built-in support for Matomo, third-party blocking and configurable language options. CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on three consent methods using the Matomo tracking code. Each method is based on different regulatory requirements, so it is important to consider your organisation’s legal obligations and tracking needs when integrating the CMP:
  1. Consent-based Tracking: For websites targeting users in countries that require prior consent for use of cookies and similar technologies for analytics and marketing (for example, most or EU and EEA countries), enable cookieless or cookie-based Matomo tracking only after obtaining visitor consent.
  2. Opt-out Tracking for CNIL Exemption: For organisations relying on the CNIL consent exemption for website analytics, limited tracking is permitted, provided that conditions of exemption are strictly met and users are offered a clear opt-out mechanism. CNIL exemption is strict and if any conditions of the CNIL exemption are not met, consent is also required.
  3. Adaptive Tracking: For websites operating outside the EU/UK/EEA, in countries where prior consent is either not required or only required when the analytics processes personal data, you can enable cookie-based tracking with consent and fallback to cookieless tracking if consent is not given (unless the visitor opts out of all tracking).
Before you start
  1. Create your Tarte au citron cloud account.
  2. Optionally, Tarte au Citron can be downloaded from Github and installed locally without an account.
  3. In the Tarte au citron account dashboard, click the three vertical dot menu and select Install.
    set up tarte au citron options
  4. Copy the consent manager initialisation script and place it in your web pages. It must be the position you defined in Tarteaucitron > Options > Accessibility settings: after the opening <body> tag (recommended) or before the closing </body> tag.
  5. Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
  6. If using Method 1 or 3 (described below), ensure the Tarte au citron Conformity settings are configured. Click the three vertical dot menu and select Options > Conformity settings:
    • Enable the explicit consent mode (recommended).
    • Default services status: set to Waiting user reply.
      tarte au citron conformity settings
    • The Conformity settings may differ if implementing Method 2 (described below).
Use Automatic or Manual mode
Once your account is set up, you can run Tarte au citron in Automatic or Manual mode.
  1. Automatic mode detects the Matomo tracking code and consent handling script on your site with minimal configuration in the CMP.
  2. Manual mode requires more steps to manually configure the consent manager:
    • Go to your Tarte au citron > Manage my 0 services, and search for Matomo.
    • Add and configure the Matomo service by entering your Matomo instance details. You can get the instance and tracking details in Matomo settings (Administration) Settings Cog Icon > Measurables > Tracking code.
  1. If you do not have the tracking code installed yet, go to Matomo > Administration Settings Cog Icon > Websites > Tracking Code and select the website you want to track.
  2. Copy the tracking code shown in the code box and paste into a text editor.
  3. Insert the line _paq.push(['requireConsent']); before _paq.push(['trackPageView']).
  4. Paste the modified tracking code inside the <head> tag on all the website pages you are tracking.
  5. If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
  _paq.push(['trackPageView']);
  (function() {
    var u="//matomo/";
</script>
<!-- End Matomo Code -->
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
Note: Ensure the Tarte au Citron script is loaded before calling tarteaucitron.init().
<script>
var waitForTrackerCount = 0;
  if (typeof _paq === 'undefined' || typeof tarteaucitron === 'undefined') {
      waitForTrackerCount++;
      return;
  // Initialise Tarteaucitron after the tracker is loaded script
tarteaucitron.init({
    //optionally add non-default Tarteaucitron configs here
tarteaucitron.services.MatomoAnalytics = {
  "key": "MatomoAnalytics",
  "type": "analytic",
  "name": "Matomo Analytics",
  "needConsent": true,
  "cookies": ['_pk_id','_pk_sess','_pk_ref'],
  "readmoreLink": "/custom_read_more", // If you want to change readmore link
  "js": function () {
    "use strict";
    // When user allow cookie
    ('Matomo cookies accepted');
  "fallback": function () {
    "use strict";
    // when use deny cookie
    ('Matomo cookies rejected');
    _paq.push(['deleteCookies']);
  // Ensure that tarteaucitron is loaded before pushing the job
  tarteaucitron.job = tarteaucitron.job || [];
  tarteaucitron.job.push('MatomoAnalytics');
document.addEventListener('DOMContentLoaded', matomoWaitForTracker);
</script>
Validate the Integration
  • To simulate different locations, use a VPN during testing.
  • Open your website and use the CMP widget to decline tracking consent.
  • In your Matomo instance, select the Visitors > Real-time report, and check that no tracking requests are sent.
  • Next, grant consent and verify that tracking starts in your Matomo instance.
  • If using cookie-based tracking, open the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were set.
  • Revoke consent and confirm the Matomo tracking cookies are deleted from the browser.
  • Perform some test actions and check your activity was not recorded in the Real-time report.
  1. Your website targets visitors in countries where CNIL or very similar exemption exists (e.g., France, Spain, Italy), or you have an establishment in such countries:
    • Configure your CMP to either load Matomo Analytics cookies and start tracking without prior consent, or
    • Re-categorise the Matomo cookies as Essential/Necessary.
    • The CMP banner must clearly inform users about the use of consent exempt website analytics tracking and include a visible and easily accessible opt-out mechanism (e.g. a link to your privacy policy with an opt-out checkbox).
  2. If your website serves a broader audience that targets visitors from countries that require prior consent for cookie based or cookieless website analytics (e.g. most of EU countries):
    • Consider splitting your banner configuration if the CMP supports region-specific geotargeting and consent rules.
  3. Follow the steps in this guide, How to include a web analytics opt-out feature on your site to add the embedded Matomo opt-out form to your website. The form includes all required JavaScript to allow users to opt-out of tracking.
  4. Alternatively, you can create a custom opt-out form using HTML and JavaScript, as explained in this developer guide.
  • Perform test actions on your website and view the Visitors > Real-time report to verify tracking requests are sent to Matomo.
  • Select to opt-out of tracking.
  • Open the browser’s developer tools and view the Application or Storage > Cookies tab to verify that the mtm_consent_removed cookie is set.
  • Perform test actions on your website and view the Real-time report to ensure no tracking requests are sent to Matomo after opting out.
  • Change the settings to opt back in and resume tracking.
  • Perform test actions on your website and view the report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
  • are not legally required (but you want to minimise the data you collect),
  • are not required for pseudonymised non-sensitive personal data or
  • are only required if certain personal data is processed.
  3. Insert the line _paq.push(['requireCookieConsent']); before _paq.push(['trackPageView']).
<!-- Matomo -->
<script>
  (function() {
    var u="//matomo/";
</script>
The following script listens for consent updates and enables/removes cookies when cookie consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
<script>
      return;
  // Initialise Tarteaucitron after the tracker is loaded<script>
  "type": "analytic",
  "js": function () {
    "use strict";
    console.log('Matomo cookies accepted');
    "use strict";
    console.log('Matomo cookies rejected');
</script>
  • Open your website and use the CMP widget to decline cookie consent.
  • Use the browser’s developer tools and view the Application or Storage > Cookies tab to confirm cookies were not set.
  • In the Visitors > Real-time report, check that tracking requests are still sent.
  • Next, grant / revoke consent and confirm cookies were set / removed as expected.
Previous FAQ: How to integrate Osano CMP with Matomo
