How to integrate CookieYes CMP with Matomo
CMP integration with Matomo can be implemented using the Matomo tracking code or Matomo Tag Manager. The Matomo Tag Manager method is covered in a separate guide.
This guide focuses on three integration methods using the Matomo tracking code.
Before you start
- Create your CookieYes account.
- Complete the necessary steps to configure your cookie banner in line with the consent method used and the legal requirements that apply to your website.
- Follow the CookieYes instructions to add the script to your website’s code. The script must be placed as the first element inside the
<head>tag on every webpage you want to track.
- If you do not have the tracking code installed yet, go to Matomo > Administration
> Websites > Tracking Code and select the website you want to track.
- Copy the tracking code shown in the code box and paste into a text editor.
- Insert the line
_paq.push(['requireConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<head>tag on all the website pages you are tracking. - If you already have the Matomo tracking code on the page, replace it with the updated tracking code:
<!-- Matomo -->
<script>
_paq.push(['trackPageView']);
(function() {
var u="//matomo/";
</script>
<!-- End Matomo Code -->
Install the Matomo consent handling script
The following script listens for consent updates and enables/disables tracking when consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
<script>
var waitForTrackerCount = 0;
if (typeof _paq === 'undefined') {
waitForTrackerCount++;
return;
} else {
document.addEventListener("cookieyes_consent_update", function (eventData) {
const data = eventData.detail;
consentSet(data);
function consentSet(data) {
if (data.accepted.includes("analytics")) {
} else {
document.addEventListener('DOMContentLoaded', matomoWaitForTracker());
</script>
Validate the Integration
- In your Matomo instance, select the Visits in Real-time report, and check that no tracking requests are sent.
- Perform some test actions and check your activity was not recorded in the Visits in Real-time report.
The French supervisory authority, the Commission nationale de l’informatique et des libertés (CNIL) allows specific configuration of Matomo Analytics to be used without prior consent, provided that strict conditions are met. This is commonly referred to as CNIL consent exemption for audience measurement tools.
Organisations relying on the CNIL consent exemption can track website visitors by default provided that all exemption conditions are met:
- The data is collected only for audience measurement their visitors are informed about and can object to tracking via an opt-out mechanism;
- The cookies or other tracking tools used solely for audience analytics;
- The tracking meets required time limits and produces specific aggregated data sets; and
- The trackers are not used for identification, profiling, or cross-site tracking of visitors.
Refer to the CNIL consent exemption for Matomo Analytics Configuration Guide (English version) or (French version).
Configure the Consent Manager
- Perform test actions on your website and view the Visits in Real-time report to verify tracking requests are sent to Matomo.
mtm_consent_removedcookie is set. - Perform test actions on your website and view Visits in Real-time report to ensure no tracking requests are sent to Matomo after opting out.
- Perform test actions on your website and view the Visits in Real-time report to ensure tracking requests are sent to Matomo.
Method 3: Adaptive Tracking
- Insert the line
_paq.push(['requireCookieConsent']);before_paq.push(['trackPageView']). - Paste the modified tracking code inside the
<!-- Matomo -->
<script>
(function() {
var u="//matomo/";
</script>
Install the Matomo cookie consent handling script
The following script listens for consent updates and enables/removes cookies when cookie consent is granted/denied. Add the consent handling script before the closing </head> tag on all website pages that contain the Matomo tracking code.
<script>
return;
} else {
consentSet(data);
} else {
_paq.push(['deleteCookies']);
</script>
- In the Visits in Real-time report, check that tracking requests are still sent.
