How do I fix the issue « Response was ‘curl_exec: SSL certificate problem: unable to get local issuer certificate. Hostname requested was: » in the archiver?
When you setup auto archiving of your reports, you may find it fails to run with the following error: Response was 'curl_exec: SSL certificate problem: unable to get local issuer certificate. Hostname requested was: host.example
When you experience this issue, there are two solutions
- If possible, address the SSL certificate issue and get a SSL certificate for your domain name running Matomo. Then the
core:archivescript will be able to talk to Matomo over HTTPS without error. -
Or if for some reason you cannot, then you can edit your crontab and add the following parameter
--accept-invalid-ssl-certificateto thecore:archivecommand for example:/usr/bin/php /path/to/matomo/console core:archive --accept-invalid-ssl-certificate --url=http://example.org/matomo/ > /dev/nullOnce the script knows to ignore the SSL certificate problem using this parameter, the error should be gone and the archiving script should hopefully proceed and succeed.
