How to set up conversion imports in Yandex Ads
Cloud Auto-hébergement
First you need to decide which goals of Matomo you want to export into Yandex Ads. Those goals need to be set up in Yandex Ads as offline conversions.
Set up the conversions in Yandex Ads that should be imported
- Go to your Yandex Metrica Account
- Click on Add Tag.
- Specify the Tag Name, Website address and the Timezone
- Click on Create Tag.
- Scroll down and click on Configure goals.
- Click on Add goal.
- Give the goal a name (This name needs to be used in Matomo later, but does not need to match a goal name in Matomo)
- Select Condition type as « JavaScript event » and set Goal ID matches the goal name mentioned in above step. Note you can change the condition required.
- Choose an appropriate option for Revenue.
Enable offline conversion
After creating the tag and goal you need to enable offline conversion for each tag.
- On the left menu click on Settings.
- Select the Upload Data tab.
- Click on Enable offline conversion tracking.
- The option to upload « offline conversion ». It takes 1-2 days to appear after you have enabled offline conversion tracking.
- After 1-2 days you would see a button Upload offline conversion in the Offline Conversion > Upload tab.
Set up a conversion export in Matomo
- Log in to Matomo and navigate to Administration
> Websites > Conversion exports
- Ensure the correct site is selected in the site selector.
- Click Create new conversion export.
- Configure the export depending on your requirements.
- For Number of days to export:
- If you want to do the import into Yandex Ads on a daily basis we recommend to use 3 days.
- For a weekly import 9 days would be recommended.
Note: Yandex Ads will automatically ignore conversions that are imported twice due to the overlapping days, but this way you can be sure no conversion is missed if the import doesn’t work correctly one day.
- Ensure the goal names you configured exactly match those configured in Yandex Ads before.
- Note: When you save the new export, the Export URL is generated with the access token included in the URL. Copy the Export URL before leaving the page as this URL, with the included access token, is only shown once. If you come back to this conversion export later, the Export URL will still be visible but it will not include the access token.
- Once the export was saved, go to the overview and click the icon to see the download link.
Setup offline conversion
Currently Yandex Ads supports upload of offline conversions using 2 methods
- via Yandex Metrica website
- via API
Note: Matomo supports only offline conversion upload via Yandex Metrica website, which means you have to upload the conversions manually daily or the time frame best suitable to your need.
- Click on Settings.
- Click on Upload Data tab.
- Click on Upload offline conversions in Offline conversions section.
- Select Binding type as
yclidand upload the file downloaded using the direct download link of the conversion export you have configured in Matomo. - Click on Upload data.
